Air Conditioning not working
Old May 28, 2010 | 04:48 PM
Joe Richelieu's Avatar
Default Air Conditioning not working
The Air Conditioning is not working on my 60,000 mile 2004 XJ8.
Does it just need a refrigerant gas top-up or should I look at replacing the fan controller module as suggested in an earlier thread?
Old May 29, 2010 | 04:50 PM
hlgeorge's Avatar
You need to give more information on "The Air Conditioning is not working".
Old May 29, 2010 | 05:18 PM
Re: Aircon not working.
The fan is not operating, even when dialed up to maximum speed, which apparently overrides the fan operation module.
With the fan not operating, no AC is operating either, so no air is flowing from the vents...regardless of temp setting.
Old May 31, 2010 | 04:41 PM
Fraser Mitchell's Avatar
OK, so the climate control fan is not working and thus not blowing air, (hot or cold) into the cabin. As you are in California, no doubt you never need any heat !!
Sounds like the fan or its control is at fault. Is there a fuse you can check ?
Old May 31, 2010 | 05:15 PM
hlgeorge's Avatar
It's the blower relay on top of the blower housing. You can access it by removing the glove box. Part# C2C39577
Old Oct 27, 2010 | 09:19 AM
hunter34's Avatar
Did this solve the problem? I have the same problem. The blower does not work for AC or Heat in Auto or Manual mode. I checked all of the fuses, and they are working.
Is there a way to test if it is the relay before ordering the part? I'd like to verify that it is this part (C2C39577) before ordering a $200 part.
Mark
Old Oct 27, 2010 | 09:25 AM
hunter34's Avatar
... and how do you get to the part C2C39577? Is it fairly straight-forward to remove the glove box?
Mark
2004 XJR
Old Nov 8, 2011 | 06:52 PM
tomscob's Avatar
Default Heat/AC oart c2c39577
Is there a way to test this item before changing out thanks tomscob
Old Nov 15, 2011 | 10:27 AM
Glendoramike's Avatar
BEEN THERE, DONE THAT!
Here is how to test it and how to change it:
https://www.jaguarforums.com/forum/x...er-quit-62390/
This is what it looks like:
Old May 4, 2014 | 07:24 AM
kingsee's Avatar
Default ac problem
HI all , need your help please , my jag 2004 xj8 , the air condition system , sometimes its cold like i live in Alaska , and sometimes its giving hot air , by it self , it has nothing to do with if the car is running at idle , or driving , some times at the starts of the day its cold and then all of the sudden it goes hot , and some times its the opposite way , its hot then i leave it on then its start to cool again ???? i notes that some times of i accelerate suddenly its goes off if it was on ( cooling )>?? any idea ??
Old May 4, 2014 | 05:44 PM
meirion1's Avatar
Jaguar recommend that you run the CC with the air conditioning on all the time.
The system therefore cools the incoming air and then heats it if you are calling for heat.
I think the advantage is that misting inside the car is reduced because as you know air
conditioning dries the air.
Do you run the CC this way ?
If you do then I can imagine these symptoms being produced by a faulty blend door (there are 7!)
1100me
Aug 27, 2020 11:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
johanasu
Sep 3, 2015 12:39 PM
martybmw
Aug 31, 2015 10:15 PM
Kristian_TT
Aug 28, 2015 02:32 AM
