Air Line Fitting Olive Orientation
Old Jan 20, 2019 | 11:35 AM
Brewster411's Avatar
Default Air Line Fitting Olive Orientation
I noticed that the olive part of the air fitting for the front struts has a flat notch cut into it on one side. Is there a certain orientation that this olive needs to sit in the valve for the system to work correctly?
(picture borrowed from SNG Barratt for illustration purposes)
Old Jan 22, 2019 | 07:29 AM
sukhoy1972's Avatar
not. put as it will, no difference
Old Jan 22, 2019 | 07:40 AM
sukhoy1972's Avatar
This cut is specially made so that when you remove it from a hose, this thing breaks down and you buy a new fitting ..... this is true.
Panelhead
Aug 8, 2016 10:59 AM
mrlovt
Nov 15, 2015 09:29 PM
arquesen
Mar 20, 2013 09:21 PM
here I go again
May 18, 2012 12:51 PM
phd12volt
Feb 4, 2010 03:55 PM
