Air suspension fault - open circuit rear height sensor
Old Jul 3, 2021 | 03:27 PM
Leslie Graham (Levitikon)'s Avatar
Default Air suspension fault - open circuit rear height sensor
Hi peeps. It's been a very long time since I posted here, due in part to the pandemic and not getting out to fix the old gal.
Anyway, my quest this summer is to get her back on the road. I connected up the iCarsoft today and checked for codes and the only one (except the battery being low voltage) was the Air suspension. I had figured, as it had slowly become a low rider, that the air had leaked out and without the battery in the car the compressor wouldn't kick in. Nevertheless, I connected a battery to it and got the following code:
C1885 - Rear height sensor open or short circuit to ground.
If anyone can give me some idea as to where to begin my investigation, I would really appreciate the leg up.
Thanks in advance.
2006 XJ8 VDP NA
Old Jul 12, 2021 | 05:34 PM
OldKarz's Avatar
I'm a bit late! However the signal on the right rear sensor is not getting to the control module. Could be sensor, connector or wiring. Go to pinpoint test G256924p19 in the workshop manual. it gives you the sequence to test for the short or open.
Old Jul 12, 2021 | 08:05 PM
Thanks @OldKarz
terryian
Aug 16, 2019 09:15 AM
LAjag
Jun 5, 2018 04:22 PM
presidential27
Sep 14, 2017 01:57 PM
PartsAndProjects
Jul 6, 2016 01:12 PM
Roger E
Nov 20, 2012 04:54 PM
