Airbagfailure
Old Nov 12, 2023 | 06:09 AM
alex van loenen's Avatar
Default Airbagfailure
Hello,
I just bought a LHD X350 from 2003 with a airbaglight on.
Reads fault code B2295 and a flash code 23
What can cause this problem ?
Old Nov 12, 2023 | 02:53 PM
flatsix's Avatar
Hi Alex, the error code relates to the side airbag on the passenger side. Either the airbag unit itself is the problem or the cable/plug wiring to it.
JLR Dealership has a special tool that, attached to the wiring plug, determines whether the side airbag unit is OK. If this is the case, the electrical connection must be checked.
Fritz
Old Nov 13, 2023 | 01:19 AM
Fritz
Thanks Fritz, where is the side airbag located ? Is it in the passengers seat ? or in the pillar
Old Nov 13, 2023 | 02:26 AM
flatsix's Avatar
The side airbag is located on the outside of the backrest. The saddler probably knows how to get there.
But i would first remove the seat and check the cables and plugs.
The side airbags do not contain an explosive charge but rather compressed gas. Even after the fault has been fixed, it is usually necessary to delete the DTC from the memory in order to get the warning lamp off.
Fritz
Old Nov 13, 2023 | 02:41 PM
Tonight i took the seat out and removed the side airbag. Saw nothing strange in the wiring. Cleaned all conections and was planning to order a new side airbag. Put it all back together and mounted the seat back. At my surprise the light went out ! Did not even have to remove fault codes !
thanks for the help !!!
Old Nov 14, 2023 | 01:41 AM
flatsix's Avatar
Sometimes it is enough if a plug has an increased contact resistance and therefore the proofing signal does not come back in the expected range during the system check. Plugging and unplugging it several times can then eliminate the error.
​​​​​​Fritz
Old Nov 14, 2023 | 06:57 AM
Wingrider's Avatar
Flatsix said;
Often a single time will do the trick.
sufi_786
Mar 26, 2023 10:01 AM
Darrol2004
Mar 16, 2023 10:05 AM
lannygray
Jul 22, 2009 09:50 PM
