Central Locking Issue
My car has developed a really strange issue this weekend. I removed the front two door cards to repair and redye them. After I put them back on, lock the car, then try to unlock again, all four doors unlock, then lock again within a second. Sometimes it goes back and forth for a few moments while it decides whether it wants to let me in or not. Same thing happens when you open a door from the inside; the rest of the doors will lock again right after. The door cards were pretty straightforward to remove and replace. Could I have screwed up something up?
UPDATE: I determined that the issue was coming from the passenger front door, so I pulled the door card off again, and reconnected everything properly. I realised I had not properly connected the pulling mechanism to the door handle and lock. Put the card back on, and now everything works as it should. Now, if only I could get that damned Boot Open message to disappear.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
