Central Locking Issue
Old Jul 22, 2013 | 12:26 PM
XJ8JR's Avatar
Default Central Locking Issue
My car has developed a really strange issue this weekend. I removed the front two door cards to repair and redye them. After I put them back on, lock the car, then try to unlock again, all four doors unlock, then lock again within a second. Sometimes it goes back and forth for a few moments while it decides whether it wants to let me in or not. Same thing happens when you open a door from the inside; the rest of the doors will lock again right after. The door cards were pretty straightforward to remove and replace. Could I have screwed up something up?
Old Jul 29, 2013 | 12:32 PM
XJ8JR's Avatar
UPDATE: I determined that the issue was coming from the passenger front door, so I pulled the door card off again, and reconnected everything properly. I realised I had not properly connected the pulling mechanism to the door handle and lock. Put the card back on, and now everything works as it should. Now, if only I could get that damned Boot Open message to disappear.
Old Jul 29, 2013 | 05:37 PM
meirion1's Avatar
Replacing the boot lock will probably cure that.
It consists of a small motor and two or three contacts which are integral to the latch.
Old Jul 30, 2013 | 01:17 PM
XJ8JR's Avatar
You're probably right, but the funny thing is that that boot motor has been busted for at least 2 years, and it just barely started giving me sass with this Boot Open message.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
handcuffsready
Sep 7, 2015 03:16 AM
