Aluminum Riser for 4.2L Engine?
Old Oct 30, 2013 | 03:18 PM
rhathaway's Avatar
Default Aluminum Riser for 4.2L Engine?
Is anyone aware of an aluminum riser for the 4.2L engine (Shown in the attached, pictured above gasket #24). When replacing my thermostat housing, riser and water pump, I noticed that an area of the riser's top sealing rim was sheared or cracked off.
I know the 4.0L solved plastic thermostat housing crack issues by reverting to aluminum. Just curious if the same de-evolution has yet occurred for the 4.2L engine, as well.
Thanks for any positive leads.
File Type: pdf
Old Nov 5, 2013 | 03:57 AM
Thermite's Avatar
I'd be surprised if they are not fully interchangeable, and ISTR seeing that someone had reported a switch on a 4.2l to the aluminium one as part of a larger revamp, and right here in the forum.
Search function should turn up the suspects...
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
jimbo1948
Sep 7, 2015 03:14 AM
OkieTim
Sep 2, 2015 12:48 PM
