Anyone here use the Qwikvalve system for Oil changing?
Old Sep 27, 2013 | 02:51 PM
trosty's Avatar
Default Anyone here use the Qwikvalve system for Oil changing?
I came across this and wondered if anyone uses it on their XJ8 with any issues?
Fumoto Valve | Qwik Valve™
Old Sep 27, 2013 | 04:43 PM
34by151's Avatar
Whats the problem with taking of the sump plug?
Also if the plug is fitted you will have to cut the under tray and have it poking out.
I'd be worried that an impact open the valve (even with the safety lock)
If you really want something like this my advice would be to fit one at the engine oil cooler
Add a t-piece to the cooler and the valve off that. Add a tube too the valve output to poke just out the bottom of the radiator undertray. I'd locate the valve behind the plastic cover on the right side of the bumper (next to the fog light)
PS not something for me though
34by151
Old Sep 27, 2013 | 05:13 PM
totalimmortal363's Avatar
Its a neat idea, but I think a better option for a fast oil change would be one of those devices that sucks your oil out through the dipstick tube.
Old Sep 27, 2013 | 05:26 PM
50324XJ8's Avatar
I have used one on my Jeep Cherokee since 1996. Great for a vehicle that you can get under easily. It saves on the splash when the drain plug is removed. It has been dependable and does not leak. I haven't tried one on the XJ.
DAVE
Forcedair1
Sep 8, 2025 01:57 PM
ZJag
26
Sep 5, 2016 03:33 PM
afterburner1
Dec 16, 2015 12:12 AM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
