Approach Lighting Question
Old Mar 28, 2008 | 10:19 AM
eastorlando's Avatar
Default Approach Lighting Question
Trying to tap into theapproachlights that are mounted under the left and right mirrors. Does anyone know what color the wire is at the door joint? Also was wondering what it's been stepped down to there (fuse designation looks like 10 amps), but I can check that with a multimeter once I figure out which wire it is.
I don't want to remove too much extra and dig into all the wires, but if nobody knows I may just get to.
Thanks in advance.
Old Mar 29, 2008 | 12:41 AM
DonsXJ8's Avatar
Default RE: Approach Lighting Question
If I may ask, what are you going to do????
Old Mar 29, 2008 | 01:03 AM
Thinking about adding some more courtesy lighting.
Old Mar 29, 2008 | 02:27 PM
jag_genius's Avatar
drivers mirror connector pin 18 green and pin 19 black
passenger mirror connector pin 18 green and pin 19 black.
these are at the mirror connectors behind the door panel..
Old Mar 31, 2008 | 08:22 AM
Yep, found that out yesterday. Didn't realize there'd be a whole nother module in the door, but it sure seemed like there were too few wires running to the door.
They're green and black out of the module and then there is a connector higher up on the door where they both become white.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
gene1
Sep 3, 2015 05:58 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
