Automatic in XJ8L sometimes does not shift into second gear
Old Jul 22, 2020 | 04:26 PM
Ronald david's Avatar
Default Automatic in XJ8L sometimes does not shift into second gear
2005 Jag XJ8L sometimes automatic sometimes sticks in first gear and will not shift to second. I can manually start in second gear but not my preferred driving. is there some electronic switch that needs replacement?
Old Jul 22, 2020 | 04:33 PM
Thermo's Avatar
Veteran: Navy
Sounds like your 1/2 shift solenoid is going out and you need to have some transmission work done. probably be a good idea to find a set of solenoids for your car, find a local tranny shop and have them do a fluid change and rebuild your shift block. probably cost you about $1000 total, but the tranny will like you a lot.
Old Jul 22, 2020 | 05:37 PM
Welcome to the forums Ronald,
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about tyour model.
NTL1991
XJ40 ( XJ81 )
Jan 23, 2016 06:05 AM
jmann324
Jul 3, 2015 08:58 AM
aleop
Apr 6, 2014 11:17 AM
jagqueen
Mar 20, 2014 08:48 AM
Terry H
Aug 6, 2013 03:02 AM
