Batt Module Volt out of range
Old Nov 24, 2011 | 06:28 PM
Drifter8282's Avatar
Default Batt Module Volt out of range
Hi All,
2006 XJ8 VDP
Got a couple of codes I need help with please...
B1671....Batt Module voltage out of range.....where is module and what is the range that it should be in ?
B2363 opt sensor failed.......what and where ?
Peter 2006 XJ8 VDP
Old Nov 24, 2011 | 07:44 PM
u102768's Avatar
According to the info I have:
Code - B1671
Fault
Battery voltage out of range from Air Suspension Module
Possible Causes
Charging system low / high voltage fault
Battery power supply circuit: high resistance
Code - B2363
Fault
Rain sensing module signal circuit fault from FEM.
Possible Causes
Rain sensing module signal circuit: open circuit, short circuit to
ground, short circuit to B+ voltage
Rain sensing module failure
Have you tried clearing them to see if they come back?
Old Nov 25, 2011 | 12:01 PM
Hi u102768, Thanks for the quick response......This was my first attempt to use my new scanner. As usual I did not read the manual till last night....after I had looked to see what codes were listed.....Will get in to it this weekend and as you suggest try and clear the codes.
Regards
Peter
Old Nov 27, 2011 | 04:13 PM
Default 2006 XJ8 Battery Module....
Hi u102768,
Code - B1671
Fault
Cleared the codes, ran the car and all is well......Thank You.
Peter
hoodun
Nov 20, 2022 02:35 PM
leep123
Sep 30, 2015 03:41 PM
reb1999
Sep 26, 2015 08:41 AM
zdrapec
Sep 25, 2015 05:49 AM
