brake rotors and pads
Old Oct 6, 2016 | 07:25 PM
Pierre's Avatar
Default brake rotors and pads
I have a 2006 black on black XJ8. I am looking to redo my brakes and am wondering if anyone out there has used aftermarket equipment. The OEM gear is 200-300 per wheel vs some more reasonably priced Zimmerman rotors and akebono ceramic pads that run ~ 100 wheel
Pierre
Old Oct 6, 2016 | 07:46 PM
Steve/C's Avatar
Those are the EXACT brake components my mechanic installed on my 05 and 07 XJ8's. I believe these are a better option than OEM, performance and cost-wise. The cost savings will even pay for a brake fluid flush and then some!
Old Oct 6, 2016 | 10:54 PM
mberman's Avatar
The Akebono ceramics are the only way to go.
Almost zero brake dust on the rims plus great stopping power. Make sure you do a complete brake fluid flush (and every 2 years). Super DOT 4 is the factory spec brake fluid.
Good luck.
Old Oct 7, 2016 | 10:13 PM
BlacXJRcat's Avatar
I used Centric premium rear brake rotors and posi-quiet semi-metallic pads kit part # 90920502 and front pads part number 10412402, I didn't get the front rotors because the existing ones were good. All from Rock Auto at a cost of $189.56. So far so good.
Old Oct 10, 2016 | 01:18 AM
Fletch44's Avatar
I used a set of siped rotors from Brake Performance in Chatsworth CA And Akebono EUR series pads. Everything works perfectly and the dust is down 80% and is almost invisible.
Old Oct 14, 2016 | 06:17 AM
lsp's Avatar
lsp
I just had a full set of E-line crossed-drilled and slotted rotors installed with their ceramic brake pads (ordered from R1 Concepts via Amazon). $254 delivered. I am looking forward to saying goodbye to the black dust on my wheels. With install, total cost was a bit less $500. (Had my upper front control arms replaced at the same time, as the ball joints were loose.)
Old Oct 14, 2016 | 08:26 AM
viper1996's Avatar
Good luck.
+1
xfgirl
XF (X260)
Jul 21, 2020 12:38 PM
bpb99
E type ( XK-E )
Oct 27, 2016 03:55 PM
Peter w
Sep 21, 2016 08:31 PM
06-XJR
Sep 19, 2016 07:47 PM
Sammy Walton
Sep 19, 2016 07:08 AM
