Can't find coolant leak
Old Nov 7, 2015 | 12:46 AM
gmcgann's Avatar
Default Can't find coolant leak
My 2004 XJR has developed a coolant leak. I can smell hot coolant when I get out of the car, and I've noticed some coolant under the middle of the car after it's parked. It doesn't leak when it's not hot. I figured the coolant was dripping onto the pan under the car and running off the back side, which is why the drip was in the middle. I knew the aux coolant pump was bad - no heat at idle - so I replaced it. (I now have heat.)
I couldn't find any evidence of a leak anywhere around the radiator or front of the engine. I left the pan off and drove the car until it warmed up, then put it back on my lift. No water under the engine anywhere, but then I found the drip. It's coming from behind the heat shield on the driver's side by the back of the transmission.
I could see it running from the heater core down the right side of the firewall behind the heat shield, but the left side? Any idea where that might be coming from?
Old Nov 7, 2015 | 01:35 AM
Torrid's Avatar
It's probably the hose against the firewall behind the block. It's a pain to get to and I've been dreading the failure of this hose on my car as well. It's just not easy to get to.
Old Nov 7, 2015 | 08:40 AM
gmcgann's Avatar
What does this hose connect to?
Old Nov 22, 2015 | 10:43 PM
josh_77073's Avatar
i had/have this same problem and its a hose that runs under the supercharger. i had my fixed and costs nearly 2grand to fix and it still leaks....
Old Nov 23, 2015 | 12:19 AM
dsetter's Avatar
This hose connects underneath the supercharger to the front block back to some other cooling.
Is only a $17 hose, but takes about 8hrs to replace it.
I did it last year, and changed most other hoses too, just to be sure.
https://www.jaguarforums.com/forum/x...valley-134108/
Old Nov 23, 2015 | 11:37 PM
gmcgann's Avatar
I suspect it's the hose under the supercharger. I ordered the parts from your post and started on the job tonight. It's going smoothly for the most part, but can you tell me how to get the false plastic firewall off? I got both side around the cabin filter and brake booster ok, but how does the center section come off?
Old Nov 24, 2015 | 05:57 PM
lcmjaguar's Avatar
Look under quick links and look at the replacing supercharger writeup, maybe some helpful info there.
Old Nov 24, 2015 | 07:27 PM
gmcgann's Avatar
I've read everything I can find. Closest thing that talked about the center section was in a thread that said you can't get to the EGR valve unless you take the center section of the plastic firewall off, but it's not too hard. I must be missing something, because I'm finding it pretty darn hard.
Old Nov 25, 2015 | 12:28 PM
gmcgann's Avatar
This is as far as I've gotten. I can't get to the EGR valve with the center part of the plastic firewall in place. What am I missing?
Old Nov 25, 2015 | 12:59 PM
34by151's Avatar
Also check the thermostat hose the is under the cast elbow, next to the S/C snout
34by151
Old Nov 25, 2015 | 04:44 PM
Sean W's Avatar
A forum member by the name of dsetter replaced his hose. He just notes to remove the hoses from the EGR but doesn't address how he removed the plastic piece to access it. It's removed in his pic so you might want to try reaching out to him directly. I'd like to know.
His post:
Old Nov 29, 2015 | 10:45 PM
gmcgann's Avatar
I got it off! Thanks for the tips. I pulled the insulation off and found there were push fasteners hidden behind the insulation, as well as double fasteners on top of AND behind the insulation.
VinnyT
Jan 25, 2016 07:46 PM
NCamie
Oct 31, 2015 10:38 AM
Catsgame
Oct 21, 2015 08:46 AM
Johnken
Oct 18, 2015 09:24 PM
mmiz8606
Oct 15, 2015 11:07 AM
