Climate Control issue, 2004 XJ8
Old Oct 11, 2016 | 03:26 PM
PartsAndProjects's Avatar
Default Climate Control issue, 2004 XJ8
Hey all! We had our first cold snap here in Virginia and noticed a weird issue with the heat in my 2004 XJ8. I did a search, but didn't see anything similar posted.
After the car warmed up I turned on the heat and the car wasn't getting warm. I started messing with vents and settings and it seems cool air is coming from the driver's side vents and rear vent and hot air is coming from the passenger side vents. Even with dual off and both sides set for 80 degrees, only the passenger side blows hot.
Anybody have similar issues or know of an issue with this? Thanks in advance!
Old Oct 11, 2016 | 03:49 PM
Partick the Cat's Avatar
There have been several threads about this and it seems that it's usually due to a blocked heater matrix/core. Do a search using 'Search this Forum' at the top of the Forum page using 'blocked' 'core' 'matrix' and 'heater' as key words; that should throw up something.
Old Oct 11, 2016 | 04:50 PM
meirion1's Avatar
This is a well known fault as Patrick has said it's due to a partially blocked heater
core.
You will need to drop and maybe remove glove box to replace it.
I have never had to do this job but I would suggest you leak check before replacing
the glove box since the fittings on the core (in and out) look pathetic.
Old Oct 11, 2016 | 05:01 PM
Sochi2014's Avatar
Before you start to mess with heater core just swap for new aux pump. It solves the issue by 105%. And yes, you definitely didn't use the Search button, the topic was discussed million times
Old Oct 11, 2016 | 08:15 PM
Thanks for the replies, everyone.
I really did try to search! Didn't get anything relevant searching for "climate control" or "heat". Thanks for the tips.
Old Oct 12, 2016 | 05:17 PM
meirion1's Avatar
I have found by experience that it is better to search using google.
Jim Goodall
Nov 2, 2020 08:24 AM
mick99
Aug 30, 2016 03:38 PM
zzjakect
Aug 29, 2016 10:42 AM
99jagVDP
Aug 27, 2016 10:16 AM
TonyG
Aug 24, 2016 12:47 PM
