Clock Light - How to change the bulb?
Old Oct 17, 2011 | 12:18 AM
04XJ8's Avatar
Default Clock Light - How to change the bulb?
Has anyone changed the analog clock illumination bulb? I miss not seeing the time at night. Any diagrams or advice on removing / installing would be extremely helpful.
Thanks!
Peter
Old Oct 22, 2011 | 10:52 AM
Glendoramike's Avatar
YEAR AND MODEL PLEASE. There is a download for X350 models' shop manual in this section of the forums. It is in pdf and you have to look something up in the index and note its number i.e. 72.50.03 and then do a search for that.
Old Oct 22, 2011 | 11:00 AM
If your handle of 04XJ8 is your model then you can use the X350 shop manual. I took a quick look and didn't find the info, but that doesn't mean that it isn't there.
Old Oct 22, 2011 | 12:08 PM
04XJ8's Avatar
Yes, it's a 2004 XJ8. The manual is the same thing that's in the glove box. It doesn't have any details on replacing dash bulbs. I was hoping somebody had done this before. Thanks for checking!
Old Jun 11, 2013 | 09:09 PM
kchirume's Avatar
was wondering if you ever figured out how to fix that light, my clock light is out too
Old Jun 11, 2013 | 09:56 PM
Gippsland's Avatar
Not much help I know,mine is out too. I "googled" it and found the procedure,bit tricky though.
Want I would like to do is use an led globe but I can't find what size it is. Any-one know?
Old Oct 9, 2013 | 06:27 PM
AhwatukeeAl's Avatar
Smile Changing XJR clock bulb video
Here's a video I posted on YouTube.
Also found that a Sylvania 2721MF is a usable replacement.
99xk8guy
Sep 29, 2025 10:51 PM
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
afterburner1
Dec 16, 2015 12:12 AM
bdboyle
Sep 4, 2015 06:16 AM
