compression check/test
Old Jul 11, 2022 | 10:38 PM
MaxTorq's Avatar
Default compression check/test
hello,
i am back to work on TRAMP and ran a compression check today.
can anyone tell me what i should be seeing or what "good readings" should be ?
i am paying hell finding any numbers....hours of surfing....oyva....
thx,
max
Old Jul 11, 2022 | 10:57 PM
Panelhead's Avatar
150 psi is great. 130 is livable. If you see cylinders under 100 psi, there are problems. BTW, what kind of Jaguar is TRAMP?
Old Jul 12, 2022 | 01:01 PM
MaxTorq's Avatar
my apologies...i get ahead of myself..
Tramp is a 2005 XJR with 78k miles.
so..i have two compression testers from Horror Freight.
both are showing 170-180 on 7 of the cylinders and 200 on the 8th...struck me as odd but ok..
your thoughts ?
THANK YOU for your response !
Old Jul 12, 2022 | 03:08 PM
Panelhead's Avatar
Default Good to go
Those are great readings. The pressures vary from cylinder to cylinder.
Indicates the valves are sealing and piston rings are in good shape.
Mendo XK
Nov 6, 2012 11:03 PM
WillyWheels
Jun 23, 2012 07:09 AM
King
Aug 26, 2010 11:59 AM
Feb 25, 2007 10:38 PM
