Compressor or Suspensions?
Old Dec 2, 2013 | 10:06 PM
Sonic's Avatar
Default Compressor or Suspensions?
Hi everyone
My XJ6 sinks when parked but lifts again when I unlock the car. Is this typically a leak in the compressor or fault with suspensions?
I had the "Air Suspension Fault" and I replaced compressor seals with bagpippingandy's replacement kit. It went away 99% but I get that fault once in awhile. Good thing is it doesn't stay on. When I stop the car n start again it goes away. So I'm assuming the compressor is not working 100% properly so is it something to do with that?
Appreciate your expert advice.
Old Dec 5, 2013 | 07:06 AM
motofreak72's Avatar
One way to find out and make sure its not a leaking air suspension is to remove the fuse for the air compressor or remove the spare and its styrofoam holder and you can access the air distribution block. Once there you can unplug both connectors. By doing either of these things overnight (it takes time and hours if your leak is minor) your car will not try and compensate its leveling system and you would see a significant drop in one corner if there's a leak. Now if there is a leak you can inspect the shock body and its valve on top with soapy water once you plug everything back on to verify the leak. It is highly unlikey the lines going to the shock are bad, but if a tire change place or mechanic putting your car on a post lift happens to crush the lines they will leak. If all seems fine and while your looking at the distribution block in the trunk I would spray soapy water around that as well. Those lines going into the block have orings and I have had to replace mine as I detected a leak there. If all is looking right than I would suspect the compressor is weak. Even though you replaced the ring on the piston it still may have weak internals. Please let me know what you find as air suspension on these cars are.....finicky
Old Dec 5, 2013 | 04:13 PM
Bagpipingandy's Avatar
it sounds like a leak, the fact it lifts when you unlock the car tells us the compression is good as the tank must be full to lift it without the compressor running, but any sinking when parked is a leak, check for bubbles with soapy water as described above, airbags and top seals are 1st suspect, then airline connections and valve block next.
regards
Andy
tlynch
Dec 31, 2020 01:58 PM
04Xjrsteve
May 7, 2019 04:06 PM
dmatthewman
Sep 30, 2015 10:10 AM
dan102877
Sep 29, 2015 06:47 PM
