Coolant leak near fire wall on passenger side
Old Oct 14, 2025 | 06:49 PM
Lisaelh's Avatar
Default Coolant leak near fire wall on passenger side
I am the proud owner of an 04 xj8. I have a coolant leak somewhere near the firewall on the passenger side. I have replaced the thermostat housing thinking that was the problem. I just can’t seem to find where it’s coming from. It looks like maybe it’s coming from a line that is covered in mesh and then it’s copper where it connects on the bottom. Does anyone have any feedback for me or maybe a diagram that I can actually see. Please help. I live in Austin, Texas and I have to work F1 tomorrow at COTA but I can’t drive my beautiful xj8 with this coolant leak
Old Oct 15, 2025 | 04:13 AM
Petz's Avatar
You might have to open up again... behind the thermostat is the valley hose . That just goes around and connects to the throttlebody (lover right side) . Put the car uphill or raise the front. To let it drain backwards so your knock sensors are not getting flooded ( corrosion damaged).
fluid coolant is Oat or G12+ silica free
Old Oct 15, 2025 | 04:15 AM
Petz's Avatar
Paasenger side near firewall can also be at the entry and exit towards the heatercore in the middle console behind radio.
Old Oct 29, 2025 | 07:44 PM
OnebadassXJR's Avatar
Originally Posted by Petz
Paasenger side near firewall can also be at the entry and exit towards the heater core in the middle console behind radio.
Aren't they metal block style lines bolted into the firewall?
Ouro
Jun 15, 2024 03:54 PM
Car Crazy
Oct 30, 2023 10:59 AM
mpasiuk
24
Mar 14, 2022 10:12 PM
atlcontracting14
May 10, 2020 03:13 PM
Drak
Dec 11, 2015 03:45 PM
