Coolant leaking from on the right side of enginer
Old Aug 18, 2020 | 09:30 PM
TimCanJag's Avatar
Default Coolant leaking from on the right side of enginer
I recently replaced my water pump because I had coolant leaking on the front side of the engine and running down the front of the oil pan drain pan. The leak on the front of the oil pan has been eliminated. Now I have coolant leaking on the right hand /passenger side of the oil drain pan. Are there any coolant hoses that run on the lower part of the engine on the right hand side? I see the two lines for the heater core, but those are dry with no signs of a leak. I only loose about a cup of fluid at a time. I have read many posts about the valley hose. Is there any chance this could be my issue? Does the valley hose leak only when the system is under pressure. My car seems to leak once I turn off the engine. Any ideas?
Old Aug 18, 2020 | 09:37 PM
meirion1's Avatar
The valley hose leaks into the valley and down the back of the engine.
Old Aug 19, 2020 | 03:36 AM
EsRay's Avatar
Further to Meirion1, you will most likely see a puddle behind one of your front wheels if it is the valley hose; on mine it was behind the driver's side wheel?
ricardoa1
May 3, 2020 02:51 PM
jackra_1
Mar 8, 2016 02:56 PM
gmcgann
Nov 29, 2015 10:45 PM
smackela
Jun 7, 2011 04:24 PM
sempire
Nov 18, 2010 09:20 AM
