Transmission Pan Plug
Old Mar 1, 2016 | 10:57 AM
jackra_1's Avatar
Default Transmission Pan Plug
I drove my XJR the other day for the first time in probably 6 week.
Then drove it again a day later and discovered a very small pool of coolant on the garage floor a short distance behind the passenger wheel and in a bit.
This has never happened before. So I put the car up on ramps and had a look around underneath.Could not see anything untoward.
However what I did find was the transmission plug had transmission fluid all around it. It was loose!
I replaced the pan about 6 months ago and thought I had made sure it was tight. Maybe I did not?
Anyway tightened it up and will check in a month or so.
No sign of any coolant leaks.
Thought I would point this out to those who have replaced their pans just in case.
Old Mar 1, 2016 | 05:30 PM
Sean W's Avatar
Next time you see a puddle, check along the trans tunnel as the hose under the SC leaks and drain at the back of the engine down the trans passenger side.
Old Mar 1, 2016 | 06:03 PM
JLR_Tech's Avatar
My XKR had a coolant leak from under the compressor and was a pain to find as it only appeared to leak while it cooled down.
Old Mar 1, 2016 | 06:51 PM
jackra_1's Avatar
This is what I am afraid of and was my first thought when I saw the puddle.
I do plan on renewing the valley hose but not until this next Winter when I have moved back up to Massachusetts.
Not at all convenient right now as I am getting the house ready to sell!
Old Mar 8, 2016 | 02:56 PM
jackra_1's Avatar
Default No sign of leak
Well In this great weather I have driven the Jag several times now and no sign
of any more coolant leakage. No sign of the coolant lowering in the overflow
tank either. I marked the level after the original leak.
So today I bit the bullet and bought a used Supercharger off Ebay.
I am going to send it away for a rebuild along with porting and a 1.5 lb pulley.
I have not decided on the company to do all of this yet and it will not be until later this year anyway. Then the valley hose and others get changed.
Then I will try selling my existing Supercharger.
Lagonia
20
Oct 26, 2018 08:57 PM
Mark1975
Mar 7, 2016 01:41 PM
Kewpie
Feb 19, 2016 04:12 PM
Qgregg
Feb 7, 2016 05:32 AM
Daniel Thomas Eakin
Feb 2, 2016 02:31 PM
