crank but won't start
Old Jul 23, 2017 | 10:49 AM
pete_185's Avatar
Default crank but won't start
jaguar x350 xj8 2005 been park for 2 years the car crank but won't start
Old Jul 23, 2017 | 10:54 AM
pete_185's Avatar
More info : the car have new battery, fuel pump works, no spark at coil. Anyone here ever been through this? thank you.
Old Jul 23, 2017 | 11:19 AM
pete_185's Avatar
More info : no codes reading, there is fuel pressure at rail
Old Jul 23, 2017 | 08:23 PM
meirion1's Avatar
Check fuses F30 and F 31 in engine fuse box
Check relay R7 in same fuse box and swap with simliar colour
Download electrical guide from sticky on this forum.
Possible CKP crankshaft posn. failure-check resistance.
More info
https://www.jaguarforums.com/forum/x...-spark-149361/
Old Jul 25, 2017 | 08:37 PM
BlackKat's Avatar
Had same issue turned out to be crank sensor. AutoZone had it for 40 bucks and its really really easy to replace.
Old Aug 17, 2017 | 10:50 AM
pete_185's Avatar
Thanks Meirion1 and Blackkat. Eventually the guy reset the front ECU and program it again and had it running.
tinyturner11
Dec 6, 2017 09:09 PM
Digger22
Oct 15, 2017 02:08 PM
thriftyshirt
Oct 14, 2017 06:51 AM
TheOne
Jun 15, 2017 09:09 PM
KenAdamson
51
May 28, 2017 12:01 AM
