CRUISE CONTROL PROBLEM
Old May 5, 2008 | 09:28 AM
2004XJ8's Avatar
Default CRUISE CONTROL PROBLEM
Had jag replace wiper motor last week now cruise is not working. Before all I did to activate the cruise was hit the set button on the wheel. Is there another button to activate the cruise control besides on the wheel? I assume they disconnect the battery to do the wiper. I do not get the cruise engaged in the display. no other messages come up. I do not beleive my car has ACC?
It was working the morning I dropped the car off for the wiper motor? Any ideas guys?
Old May 5, 2008 | 09:49 AM
FactoryJaguarTech's Avatar
Default RE: CRUISE CONTROL PROBLEM
Did it work when you picked it up or did you just try it now?
I would try disconnecting the battery for 5 minutes first. If still no joy then take it back to them and tell them it is not working since they replaced wiper motor.
Old May 5, 2008 | 10:18 AM
2004XJ8's Avatar
Picked it up friday eveningand just used cruise this morning on the way to work. It worked the morning I dropped it off.
The diagnostic report for the wiper mote said they tested the wiper switch I assume that the switch on the steering collum.
I wonder if something got messed when they did that.
Old May 5, 2008 | 11:13 AM
It is unlikely, but not impossible. Would have to be someone pretty careless working on your car. I would just take it back in and give them the "since ya did this......" speech.
Old May 5, 2008 | 11:55 AM
2004XJ8's Avatar
What does diconnecting the batteryfor 5 minutes do?
do I disconnect both positive and negative leads?
Old May 5, 2008 | 12:01 PM
2004XJ8's Avatar
I forgot to thank you for the info.
One other thing how do I find out if my car was prewired for bluetooth the sticker says nothing about having it. it does have nav? is it a sperate module and is there anywhere to get them besides jaguar?
Old May 7, 2008 | 05:04 AM
Pull negative cable off battery. Is known as hard reset. Sometimes the electronics glitch. Helps make them smooth again.
Do you have phone in your car now?
If so, all you need is the Bluetooth module. If not, you need about 1500.00 in parts to make it work.
Old May 7, 2008 | 09:23 AM
2004XJ8's Avatar
PRESS THE PHONE BUTTON AND THE SCREEN SAYS NOT FITTTED I ASSUME THAT MEANS I DO NOT HAVE PHONE INSTALLED?
i NOTICED IN THE XJ8 2004 AND UP SECTION SOMEONE HAS A POST ABOUT SOME PHONE MODULES. i RESPONDED WITH SOME QUESTION IN THAT POST. i NOTICED YOU RECOMMEND A MOTOROLA BLUE TOOTH INSTEAD OF BUYING THE JAGAUR UNITS? ANY COMMENTS ON THE QUESTION I ASKED ON THAT THREAD?
THANKS
jdzubas
Oct 4, 2015 09:14 AM
XJsc-guy
Sep 25, 2015 11:09 AM
Skeeter
Sep 17, 2015 08:15 PM
edtexas
Sep 4, 2015 08:20 PM
XFR_Gold
Sep 2, 2015 12:24 PM
