Daimler Super V8 Rev Problem
Old May 1, 2009 | 08:22 PM
roverlr3's Avatar
Joe, Let me start by saying I'm not a mechanic and I can't answer your idling query nor do I have any idea on what's going on there, however I believe the water being expelled out of the exhaust is nothing more than condensation (warm exhaust gases passing thru cold metal exhaust tubing). If I understand you correctly, the water stops running from the exhaust pipes after the car warms up. This is normal and happens to me on all my cars on start up on cool mornings. Hope that helps.
Jeff
Old May 1, 2009 | 11:27 PM
DavidB's Avatar
What you describe is completely normal--by design, your engine shouldn't rev over 3000 rpm with the transmission in neutral or park.
TTYL
David
Old May 2, 2009 | 03:15 PM
JackJohn's Avatar
Originally Posted by chromeglobed1
whilst not being driven it is regularly started and the engine run for approx 20-30 mins at a time.
After one of its usual turnovers the accelerator was pressed to increase the revs and at this a good deal of water ejectede from both back boxes of the exhaust .This lasted for about 5 or 6 presses of the accelerator pedal
Hi Joe, I agree with Rover on the water expulsion. It is condensation. Another thing to bear in mind, 20 to 30 minutes idling (even with the occaisional rev thrown in) is insufficient to dry out the exhaust system from a cold start. Driving of course will dry it out quicker. If condensation is left in the system, over time it can cause problems with the O2 sensors among other things. You don't say where you live but here in the Houston area, it could take close to an hour to evaporate all the condensation from an exhaust system at idle only.
JaguarLover101
48
Jun 12, 2023 10:28 AM
aarahim
Aug 31, 2021 11:04 AM
jdzubas
Oct 4, 2015 09:14 AM
johns427
Sep 28, 2015 09:29 PM
