Dash Command Says 79% Throttle Position Max
Old Jun 16, 2014 | 10:23 PM
mbalce's Avatar
Default Dash Command Says 79% Throttle Position Max
Have a 2006 Super V8 Portfolio. Picked up one of the ELM WiFi OBD2 interfaces and purchased Dash Command for my iPad. One interesting aspect is that when I have the pedal at WOT it is showing my pedal position to be 69% and the throttle is at 79%.
Is there any way to adjust this on my car? Would think it should be at or close to 100% when I have the pedal mashed to the floor.
And yes - I did check to make sure the floor mat is not blocking the pedal travel at all.
Thanks,
Mark
Old Jun 17, 2014 | 02:28 AM
34by151's Avatar
It mist be that Dash Command is not reading the values correctly
I would get the the results from SDD first
34by151
Old Jun 17, 2014 | 05:48 AM
JagV8's Avatar
Generally the pedal sensors don't go to 100%. Instead, the PCM watches for the max ever seen and treats near that as 100% (but reports the value rather than the 100%). Even so, yours looks low.
Similarly, zero is not zero but near the smallest actually seen.
xjrjag
Oct 24, 2024 03:09 PM
MrWest
Dec 1, 2015 09:18 PM
Ipc838
Sep 13, 2015 03:27 PM
1964Daimler
Sep 9, 2015 11:28 AM
mrplow58
Sep 9, 2015 11:27 AM
