DCS/ABS problems =dangerous problems
Old May 2, 2019 | 06:28 PM
special effects's Avatar
Default DCS/ABS problems =dangerous problems
04 XJ8 BRG on Tan
Hi all
was hoping someone had an idea to what is going on with my favorite ride....
I was having the wonderful "suspension fault" warning for a month or so. It slowly grew more frequent and took longer to clear on its own.. The suspension then started going all the way up in front.. I had to let air out of the front struts to drive it... I tested the compressor the best I could and replaced it with a new unit. after which the compressor would run for a moment and then stop with the car remaining on dead bottom.. I determined after a hard reset that the ECU was not letting the valve let air into the tank or struts.. I was under the impression I would need to go into the system with DDS and reset it.. I purchased a new computer and a program from Ebay but was unable to get past login... eerrr very frustrating.... I had to travel for work so the car was left where it was untouched for over a week... When I returned I needed the space to repair my old favorite ride to use so I started the XJ up to move it and low and behold the suspension started to work... I was thrilled that it "fixed itself".. the car pumped up and seemed to stop about where it belonged so I hopped in to go for a test ride... Upon even the smallest acceleration the right rear wheel spun up as if were on ice... When I finally got up to some speed and depressed the brake pedal the ABS activated like crazy.. The car is unsafe and very unpleasurable to drive..Anyone have a clue what is wrong with my favorite ride???
Old May 3, 2019 | 01:23 PM
wwr's Avatar
wwr
special effects;
It could be helpful to know what the car 'thinks' is happening. Do you have a scan tool capable of reading the error codes, including the Jaguar specific codes? This would be a good starting point.
Search the forum for info on recommended code readers and interpreting these codes. There is also a DTC Summaries document available on the forum with explanations for each code.
Reply back with specific codes and I suspect you'll get some suggestions.
Best Regards, William
superchris
Exterior
Jul 17, 2018 12:44 AM
Openside
Jul 18, 2015 12:52 PM
Mikey Musson
Aug 13, 2013 07:11 PM
edhowey
Jan 22, 2010 03:25 PM
lowell216
Nov 16, 2007 06:07 PM
