paddyx350
close
- Join DateFeb 2018
- LocationWexford
Liked:230 Times in 152 Posts
When I turn off the drivers seat moves backwards and does the reverse when I start up.
Does anybody know how to stop this feature?
[/B]Simply turn the selector switch on the left side of the steering column from center (Auto) to Pedal or Column.
Fraser Mitchell
close
- Join DateDec 2009
- LocationCrewe, England
Liked:2,548 Times in 2,021 Posts
+1
What I do is position the switch as per the advice, and in addition, move the seat back a bit and enter this into the 2nd memory setting. When I exit the car I can then move the seat back myself if I want to. I found that the seat moves too far back if you let the auto feature work. This gets round that excessive movement.
Wingrider
close
- Join DateSep 2016
- LocationStow Ohio
Liked:879 Times in 731 Posts
Disconnecting the battery, will erase any seat memory setting on either of mine. Just adjust seat where you like it, & leave it alone. That was what was done to mine, found out after working on it early on, as i had to disconnect the battery.
