Does This Look Familiar?
Old Aug 20, 2024 | 07:46 AM
04Xjrsteve's Avatar
Default Does This Look Familiar?
This was found while sweeping up. Appears to be some kind of protector for a pipe or hose as it passes through a wall. Using my minds eye, I have gone through everything imaginable but I can't imagine where it may have been. Could it be from the x-350?
Thanks & best,
Steve S.
Old Aug 20, 2024 | 12:27 PM
clubairth1's Avatar
Community Influencer
Not sure but remember something kind of similar under the air box in my old 2005 STR? The plastic pin from the air box went in the center and then the large outside lip snaps down into the sheet metal of the body. But I remember mine being black rubber and not white so maybe wrong here?
Old Aug 20, 2024 | 01:43 PM
04Xjrsteve's Avatar
Default I Think YUou Got It!
Thanks, Clubairth! The air intake tube that fits over the Throttle Body fits onto a pin underneath & at the front. I believe that is the only place this could have been. It would ameliorate vibration between the engine & the metal tube. I will check to see if this is it and let you know.
Best,
Steve S.
04Xjrsteve
Jun 23, 2024 05:12 PM
h2o2steam
Jun 19, 2024 05:16 PM
gmacaz
Apr 13, 2023 06:38 PM
Stamford
Sep 9, 2020 08:17 PM
Z07Brandon
Feb 29, 2020 08:10 AM
