Drivetrain vibration
Old Mar 26, 2022 | 10:03 AM
Don B's Avatar
Originally Posted by GermanXJ
Checked the front yesterday: Left front wheel jacked up no vertikal or horizontal play, right side jacked up no vertikal play but when im trying to test horizontal play i can feel a considerable amount of play in combination with metallic clunk and movement of the steering wheel. Is that normal behaviour?
With both front wheels off of the ground, it is normal for the steering rack to move when horizontal/side-to-side force is applied to either tire, but the metallic clunk doesn't sound normal. It would be worth investigating that more closely for the source of the clunk. Do you notice any play in the steering wheel while driving?
Cheers,
Don
Old Mar 26, 2022 | 11:04 AM
GermanXJ's Avatar
Thanks for your reply Don. No play in the steering while driving, also no play in the steering when both wheels on the ground and car is static.
Got to add: It doesn’t seem to be play or move in the axles or the tie rods - neither inner nor outer. Seems like it’s in the power steering itself.
It‘s also no real „play“. When I horizontally move the jacked up front right wheel then it’s directly transferred to the steering wheel which moves the same way (in combination with the clunk).
But when I do the same with the jacked up left wheel there is no „play“ at all. Neither at the wheel nor at the steering wheel.
I don‘t know about the construction of the specific power steering of the XJ. Is that „play“ normal and part of the construction?
Old Mar 26, 2022 | 10:02 PM
Don B's Avatar
Here's another test you can try: with the car raised, either on ramps or jack stands, reach up and wrap a hand around the steering column. Twist it clockwise and counterclockwise and try to detect any play in the pinion of the steering rack and listen to see if your clunk is coming from the pinion housing of the rack. Also, shine a light up on the lower steering column U-joints. Here's the parts diagram showing the two U-joints:
Cheers,
Don
87LC2
Nov 14, 2020 11:33 PM
ReluctantMechanic
May 20, 2020 12:37 PM
VinnyT
52
Aug 29, 2016 11:08 AM
eastwildlife
Apr 15, 2011 10:42 PM
Hamish
Aug 19, 2010 10:19 PM
