DSC Disabled While Driving
Old Jul 10, 2008 | 07:14 AM
mosesbotbol's Avatar
Default DSC Disabled While Driving
The DSC Disabled lightcame one while driving and I could not enable it. I had to pull off the highway, shut off the car and turn it back on. When the car restarted, it was enabled.
What caused this to shut off?
Why couldn't I enable it while driving?
Old Jul 10, 2008 | 10:58 AM
Default RE: DSC Disabled While Driving
Don't shut the engine down as this might kill lights and message and make finding the faultdifficult. Moreover, you would at least have prove that the lights came on without prompting! Good luck.
That's going to be hard to keep the engine running and stop everything to get to a Jag dealer. Let's see how frequent this light comes on first.
Old Jul 12, 2008 | 02:57 PM
veffremov's Avatar
I have the same issue: "DSC Not Available" message comes up, clears after restart. I could drive a week with the light off, then it would come on every time I drive.
I did a little research on this error. The DSC module, which is combined with the ABS, is connected to a lot of systems and sensors in the car. If it detects failure or even signal inconsistencies between the sensors it will cause this problem. I have a few TSBs how to diagnose this and it could be quite labor intensive. I would also recommend going to the dealer and not a local shop as the computer diagnostic equipment seems to be fairly specific to the car.
Even if the light is not on the computer will store the failure codes, however almost all diagnostic routines call for clearing the codes, swapping sensors and checking if the codes come again, which would be rather tricky if the failure is not consistent.
I'm saving pennies from my morning coffee and trying to improve my mental stamina before going to the dealer with this problem as it could be a long a costly endeavor.
Good luck and let us know how it turns out.
cissdm
May 3, 2016 06:02 AM
JimMLiny
Sep 9, 2015 08:13 PM
Xkr x100
Sep 6, 2015 08:50 AM
mcdutch
Sep 4, 2015 03:38 AM
