DSC Not Availiable - Brief Message on Start Up
Old Feb 26, 2017 | 09:40 PM
martin49315's Avatar
Default DSC Not Availiable - Brief Message on Start Up
I have a X350 2007 XJ TDVi - noticed on start up a few times recently that the warning message 'DSC Not Available' flashes up on the message screen but goes off again after maybe a second.
No amber warning light comes on an no issue with 'safe mode' or reduced power - the message just flashes briefly at start up.
Has anyone else encountered this - Is it normal for this model as my previous X308 did not do this??
Thanks.
Old Feb 27, 2017 | 06:20 AM
Rajabrooke's Avatar
Have had the same issue on start up on my 2005 super 8. No idea I'm sorry to say.
Old Feb 27, 2017 | 06:27 AM
jimbov8's Avatar
Usually a sign of your battery being slightly under charged. I would charge it overnight and then report back.
Old Feb 27, 2017 | 06:33 AM
Cambo's Avatar
Yep, your battery is low
Old Feb 27, 2017 | 06:36 AM
Rajabrooke's Avatar
Thanks Jimbov - confirms mine & my mechanics issues with a slightly(supposedly new ) battery which has been causing multiple codes been thrown out intermittently.
Old Feb 27, 2017 | 08:22 AM
Partick the Cat's Avatar
Yep I used to get that when the car had been unused a week or more, and before I got a CTEK charger/minder.
Old Feb 27, 2017 | 10:10 AM
Rajabrooke's Avatar
Thanks guys for the input - have been charging the battery but it seems to be losing voltage. (New battery will fix that). Bigger issue seems the body harness - some of those wires aren't carrying the full voltage. So it seems it's a combination of both that are causing suspension & power restrict codes intermittently. Just got the car a month ago so not looking to fork out for a new body harness just yet if I can find a work around. Its double the price in my neck of the woods due to tax on imported car parts.
All this due to bad paint job in the oven .
Will let you know how we resolve this
Old Feb 27, 2017 | 10:15 AM
Rajabrooke's Avatar
Sorry Martin for somewhat hijacking your thread but thanks for highlighting it.
Old Feb 27, 2017 | 10:52 AM
I was a little suspicious that it might be something like the battery, hopeful it was something potentially that simple toI!!
A friend of mine had an X type that was having all sorts of issues with sports mode and through trial and error it was discovered that his battery was at fault also, after changing the J gate and various other bits and pieces had no effect!!
The car has to go in in the next week or two before the timing belt so I will get them to test the battery while it's in there.
Old Feb 28, 2017 | 12:53 AM
Rajabrooke's Avatar
On the mend,but battery not the problem - being drained because of harness/wiring leaking - have isolated those with relays etc.
