Engine swap from 04 XJ8 to 08 XJR
Old Mar 19, 2024 | 11:22 PM
Cookmechanic's Avatar
Default Engine swap from 04 XJ8 to 08 XJR
I'm currently in the process of swapping my 04 XJ8 engine and found a good price for a 08 XJR engine. I have already bought it and I have seen a few differences. I plan to add the Super to it eventually but for now I want to get it to run. I noticed the VVT solenoids are not on the 08 engine as well as the knock sensor that have different ends. If anyone can help me it would be much appreciated.
Old Mar 20, 2024 | 10:29 AM
Wingrider's Avatar
Unable to provide the information that you need.
But the 04; & 05's are a little different from the later models.
They are listed seperatly on the readers.
The Jaguar specific readers give a lot less information.
For my 04's motor, compaired to the 07's
Old Mar 20, 2024 | 10:52 AM
clubairth1's Avatar
Community Influencer
Not sure but?
The 4.2L SC engine got VVT for 2006 and up? So the 2008 SC 4.2L V-8 should have VVT?
The 2004 4.2 NA engine had VVT from the beginning?
Are you trying to install a SC engine in place of a NA one?
You do know that without the SC that engine will be a dog?
I know as I had a 2005 STR and broke the SC belt once. Car will operate fine without the SC but it will be slow!
Old Mar 20, 2024 | 12:04 PM
Six Rotors's Avatar
How can a pcm in a 2004 XJ NA run a 2008 XJ Supercharged engine?
Old Mar 20, 2024 | 12:32 PM
Wingrider's Avatar
Hopefully he acquired the module along with the motor.
If not, can't any 08 XJR module be programed to work?
Old Mar 21, 2024 | 08:42 AM
wfooshee's Avatar
From what little i know about it, from folks asking about adding a supercharger to the existing engine, is that the engines are internally VERY different, and the electronics are different as well, meaning the control unit from a non-SC car won't know {bleep} about a supercharged engine, even if installed without a working supercharger.
Which brings up the question about "I plan to add the Super to it eventually." Can you even do that? Remove the supercharger hardware and put on a conventional intake manifold? All that plumbing up there is completely different: where the coolant hoses attach, the location of the throttle body, EGR, and all of that. And as was point out above from someone who lost the belt, the SC engine will be a pig without the SC.
This is a really deep rabbit hole, I'm afraid. NA and SC engine are NOT interchangeable, aside from the model year gap. I would sell the XJR engine on and find the correct engine for the car.
Old Mar 21, 2024 | 09:53 AM
clubairth1's Avatar
I would listen and read wfooshee post several times before going any further.
I can't add anything and fully agree this will not work and you are WAY, WAY over your head!
Just buy another car as you will be far ahead financially compared to this Frankenstein your planning to build.
Old Mar 21, 2024 | 04:12 PM
Six Rotors's Avatar
Yes. That was the point of my previous post!
Old Mar 22, 2024 | 07:59 AM
clubairth1's Avatar
Your right Six Rotors!
Cookmechanic
XJ XJ12 ( X305 )
Mar 19, 2024 10:27 PM
Cookmechanic
Mar 19, 2024 08:15 PM
98Jagxjr
Oct 31, 2023 05:57 PM
LockBee1390
Nov 8, 2022 11:29 AM
pcolapacker
May 12, 2021 06:56 AM
