Extra engine noise when turning right
Old Oct 23, 2021 | 03:42 AM
keltik's Avatar
Default Extra engine noise when turning right
2005 RHD XJR. Bizarre question but I can hear/feel the engine significantly more when turning right from a intersection or roundabout.
Can't find any exhaust leaks, nothing is touching the body, subframe and engine mounts look good, wheel bearings are all fine.
Have only had the car 3 weeks and while most of its problems were super easy to fix (dead door speakers, stuck rear blind, dodgy tyres) this has got me stumped.
Old Oct 23, 2021 | 12:57 PM
jackra_1's Avatar
Does it happen when stationary with wheels turned full right?
If not it would suggest the engine is moving more than it should when car is travelling?
Just a thought.
Old Oct 23, 2021 | 02:57 PM
xalty's Avatar
exhaust is sealed with a moving ball flange it could be loose
Old Oct 24, 2021 | 09:27 AM
Panelhead's Avatar
Default Noise?
Can you describe the noise and level?
XJR are hard on motor and transmission mounts. There are numerous posts on these failing on NA models too.
To visually check, put in drive with foot hard on brake pedal. Gently increase rpm to see lift on engine. A broken mount will be obvious. The transmission is harder to check. Put on lift and pry on tail shaft to check vertical movement.
Suspect many x350 XJR have broken mounts. Especially the transmission. Too hard to diagnose.
Old Oct 24, 2021 | 10:07 AM
Wingrider's Avatar
+1 on the motor & or transmission mounts
Old Oct 24, 2021 | 04:28 PM
keltik's Avatar
I've had a prybar on the transmission mount and it looks good. With the engine loaded in drive, the motor mounts have a normal amount of flex. I cant see any evidence of an exhaust leak and the noise isn't right for that.
I did manage to capture it on camera but its so minor you're going to need headphones for this one. Noise starts at 12seconds.
Old Oct 25, 2021 | 12:40 PM
jackra_1's Avatar
Have you tried with the car stationary yet?
Cannot hear it in that video too much extraneous noise.
Kev-P-
Jul 3, 2020 09:37 AM
hades281
Feb 24, 2018 08:28 AM
vincent661983
Sep 29, 2014 05:46 AM
Gille
Jun 4, 2014 09:18 PM
santos007
Jun 14, 2013 10:32 AM
