Failing Alternator Advice
Old Mar 14, 2014 | 10:56 AM
GregW's Avatar
Default Failing Alternator Advice
Anyone have experience with a failing alternator on an X350?
Just 60 days after my Select Edition Warranty expires the car begins howling every other day.
My indie mechanic takes a look and says the alternator is worn. He finds this surprising though as he seldom sees them go on the X350, especially on a car with just 60k miles. He calls around and alternators aren't stocked by many parts suppliers. A rebuilt unit is nowhere to be found so the only option is new for $700.
I pick the car up and the howling is gone (temporary no doubt, unlike a cut on the finger car parts don't heal themselves). Still I've bought a window of time to research.
Has anyone else had an alternator fail early? If so what symptoms did the car present? And any suggestions on sourcing a replacement part? I called a couple forum sponsors and the going rate appears to be $700 with a few days notice for them to source the part. Is the only option to buy new?
Old Mar 14, 2014 | 11:21 AM
GregW's Avatar
Default Parts on eBay
A couple suppliers on eBay list brand new units for $160 - $180 range, well below the $700 range I've been quoted elsewhere. The eBay suppliers have tens of thousands of feedbacks and 99+% positive. Any thoughts or advice on going the eBay route for car parts? An 80% discount is significant, and the parts come with a one year warranty, but is this too good to be true?
Old Mar 14, 2014 | 04:47 PM
Cburden0127's Avatar
Hi I have a 2000 xj8. I do all my work myself so I put a new alternator on my car. I paid 170 for a Denso replacement alternator I put that on 3 years ago and never had a problem. U just need to make sure the amperaage output is correct for your car. A 2004 xj8 can't b much different an alternator is basically the same nomatter what year. If u are going to a mechanic they can sometimes mark up the retail price double what they pay for it. I know u can get a top of the line alternator with a lifetime warranty for 350. I have had about 20 jaguars in my life all different years and I have used aftermarket and rebuilt alternators and I don't remember ever having a problem. It's the output voltage is what is important. Symptoms of a bad alternator would be constant dead battery. Usually a warning light will come on that happens when the alternator starts charging below 12.5 volts. Also u could see the headlights seem dimmer than usual. Also another sign could b a wining sound comming from the alternator because a bearing is bad. I do think yours went way earlier than should have but electrical parts have been known to b defective. These are my experiences. Good luck
Old Mar 14, 2014 | 08:54 PM
Lagonia's Avatar
Howling noises that come from the engine bay are more often than not from failing bearings. The number one problem on many cars that I had that developed this "howling" noise was either a bad belt tensioner or a bad idler pulley. Their bearings essentially dry up and disintegrate with heat and time. Make sure is not one of those before spending the big bucks.
Old Mar 17, 2014 | 09:52 PM
Gazoo2's Avatar
Bearings also go bad in alternators too. Any competent alternator rebuilding shop should be able to completely rebuild a Denso or Bosch alternator for around $200.
Wahooesprit
Dec 23, 2019 02:01 PM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
Havigdort
Sep 13, 2015 04:42 AM
Doovoe
Sep 8, 2015 05:42 PM
jaguarbill
Sep 5, 2015 11:43 AM
