Firewall - best pass thru for new wires (alarm)
Old Feb 13, 2020 | 12:14 PM
200Volts's Avatar
Default Firewall - best pass thru for new wires (alarm)
Does anyone have a recommendation for the best place to pass a few wires through the firewall (2006 VDP)? It's obviously a huge pain to see from either side, let alone run wiring (I've done this on many other cars, including dirilling/grommets/silicone).
I'm adding a Viper alarm with a proximity sensor - it will trigger when someone is near the car (had a side window broken by theif)- or motion inside the car. Plus I'm going to add a built in/hidden radar detector.
I'm thinking of placing the alarm brains behind the glove box, and try to run wires near the air intake plastic housing/filter for the cabin air. I'm going to try to put the proximity sensor in middle console between the seats, so the front windows (outside) have good coverage.
Any suggestions are appreciated. Thx
Old Feb 13, 2020 | 05:22 PM
Wingrider's Avatar
Find an existing hole if you can to run your wires through, if there is room enough.
Old Jan 16, 2021 | 12:02 PM
scooterforever's Avatar
Did this routing work out for you? I'm installing a water temp sensor and haven't seen a better approach yet.
- scooter
Old Jan 17, 2021 | 09:09 AM
MCFastybloke's Avatar
Bonnet release grommet, on RHD cars this is in the Left footwell and accessed from under the pollen filter.
Old Jul 6, 2021 | 08:28 PM
Thank you; this ended up been pretty easy to access. On LHD cars it's to the side of the brake booster, and enters the cabin on the left side of the driver's (left side) footwell.
fkj123
Oct 15, 2017 11:25 PM
ccx004
Nov 9, 2014 09:11 AM
1964jaguar420
Jun 18, 2014 12:23 PM
vai1953
Nov 15, 2010 05:49 PM
abwoon
Sep 5, 2009 12:54 PM
