The Flasher strikes again
Old Jun 2, 2016 | 02:39 PM
PDMiller's Avatar
Default The Flasher strikes again
Sorry to dredge up this old topic again but I wonder if anyone got to the bottom of the annoying headlight flashing phenomenon. After many months of abstinence the old girl put on a show today just to keep me on my toes. Today was dry, bright and I was traveling at normal speed. It can also happen when raining, snowing moving, stopped and even once as I was getting out of the car with engine stopped and ignition switched off. Where the £&%% does it get a feed from?
I don't suspect the sensor or the switch because the lights flicker off and on rapidly but looking at the wiring diagram it would seem that the front electronic module controls the lights so maybe that's where the fault might lie.
Any theories or thoughts most welcome
Pete
Old Jun 3, 2016 | 08:01 AM
Fraser Mitchell's Avatar
The lighting switch on the steering binnacle would be my main suspect. I noticed during the day that the sat-nav screen would flicker to "Night". At night the lights would occasionally flicker, and then one night, they totally went off for about 3 seconds on a dark, moonless, night on a twisty road. Not good !!
A new binnacle switch cured it.
Old Jun 4, 2016 | 03:00 AM
PDMiller's Avatar
New (second hand ) switch winging it's way here right now, brand new is silly money so thought I'd chance a used one. If it doesn't work I can try to fix it without wrecking the original.
Thanks for the reply
stevepaa
Aug 22, 2016 09:55 AM
Wayne Lea
Jun 13, 2016 11:37 AM
XXCalibar
Mar 29, 2016 05:20 PM
tibam13
Mar 26, 2016 05:58 PM
