Flat Battery...
Old Oct 18, 2013 | 06:31 AM
Jaygee's Avatar
Default Flat Battery...
Went to start car on Monday 2003 XJ6 3.0 SE, turned the key and nothing except messages saying Suspension fault and Steering column locked....
turned out to be a flat battery , multimeter showed only 8.9 volts..
Put smart charger on and after 72 hrs it still showed only half charged.
I was about to order a new battery when i remembered i had left the Elm Bluetooth plugged into the diagnostic socket . After removing it the charger showed full charge within an hour.Once started no faults showing...
Now what i would like to know is: would this discharge the battery or was it just a coincidence?
All views welcome.
John....
Old Oct 18, 2013 | 11:04 AM
trosty's Avatar
Is the diagnostic socket switched power? If not, then the device could be trying to constantly scan and communicate with other devices whilst its parked. I would still get the battery checked properly though.
Old Oct 20, 2013 | 07:07 AM
Jaygee's Avatar
The Elm diagnostic gets power as soon as it is plugged in even without the ignition switched on..
i have watched the battery since removing said Elm and it is still sitting around 12.3 v at the cigar lighter socket using one of these..
Or testing battery with a multimeter...and 14.6 v with engine running..
Regards... John...
Attached Thumbnails Flat Battery...-%24t2ec16hhjgkffm5pbdghbsyttwhmqg%257e%257e60_12.jpg
Poet
Feb 7, 2025 02:18 PM
jluckcuck
Nov 6, 2015 07:49 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
