Front end sagging overnight 2005 Super V8
Old Apr 21, 2016 | 06:39 AM
Louenigma's Avatar
Default Front end sagging overnight 2005 Super V8
Hello to all,
I recently removed my car from winter storage. Prior to storage I put front jacks on the front end to prevent the car to sag and drop completely during it 5 months storage.( I disconnect the battery) I don't really jack the front up, just put a block of wood that just snuggles against the jacking points, I.ve done this every year since I own this beauty. When I remove my car from storage , I start her up, front end raises up just enough to remove the 2 blocks and off we go.
This year however when I started her up I got a vehicle too low message , but disappeared after the compressor started and went to correct height.
Now I've noticed that when my car is parked overnight I notice that the front end is sagging. I start the car but no "vehicle too message" message , the front end raises up eventually . I have to say that its been kind of chilly at nights here in Montréal, Canada, maybe this has something to do with it?
Any suggestions on probable causes and what I should look for? I hate seeing my front end sag.
Thanks a million to all.
Enjoy your day!
Old Apr 21, 2016 | 02:29 PM
Fraser Mitchell's Avatar
Sounds like you have a slow leak at the front on one or even both air springs. It could be the air connectors or the top inner air seal. Normally if it is the main spring diaphragm, the leak is more pronounced, and often the diaphragm just lets go big time. It may be time to go round with a can of leak detector and see where you get bubbling. My money is on a top seal, or maybe where the air line connects to the air spring.
Old Apr 21, 2016 | 11:30 PM
JBzXJ40's Avatar
The air suspension on these cars are susceptible to cold climate, meaning that the front end will lower over night due to basic science of cold air contracting. Do you get any other warnings?
Old Apr 22, 2016 | 06:02 AM
Louenigma's Avatar
Thanks for the help, I haven't had any warnings whatsoever. I will take a wait and see attitude with this issue, its probable the chilly nights and mornings as you say. will keep you informed.
Old Apr 22, 2016 | 06:15 AM
Louenigma's Avatar
Thanks for your reply, I did a little test yesterday afternoon. after viewing some YOU TUBE videos on suspension issues on these Jags, I started the car, and sprayed some soapy water on the air line that screws to the top of the Bilstein strut, this is found in the engine bay , one on each side. To my surprise the passenger side had some bubbles appearing from the brass bolt that screws the hose onto the nipple from the strut. I attached a picture of the strut. I am talking about the brass connecter on the upper part.
What should I do now?
Attached Thumbnails Front end sagging overnight 2005 Super V8-2710-lrg-02%5B1%5D.jpg
Old Apr 24, 2016 | 08:40 AM
derik's Avatar
My first response was it's normal since mine does the same thing in cold climates or if it sits for weeks without starting. Then I read on and saw you found a leak.
Keep us posted on if there is a fix or if you have to replace that shock/strut.
Old Apr 25, 2016 | 09:18 PM
hafren's Avatar
Have a look at this thread https://www.jaguarforums.com/forum/x...roblem-110808/
dsetter
Jul 22, 2016 03:39 PM
DandyAndy
Jul 1, 2016 07:24 PM
marky151
Apr 21, 2016 05:14 AM
DandyAndy
Apr 21, 2016 05:07 AM
jackra_1
Apr 18, 2016 05:21 AM
