front lower control arm 2003 v6
Old Apr 6, 2016 | 12:43 PM
clivedavies's Avatar
Default front lower control arm 2003 v6
Just had the front control arm changed (Banana shape)-I was thinking of refurbishing the old one- Does anyone know the part number of the small bushing?-The large bush seems readily available.
Is this worth the effort?
Old Apr 6, 2016 | 02:31 PM
Fraser Mitchell's Avatar
The small bushing is available freely on the internet, although the part number escapes me. Whether it's worth doing the bushes now you have a new arm fitted only you can say. I suppose it will be ready when the new bushes on the new arm fail, (as they will), in around 70k miles !
Old Apr 6, 2016 | 08:32 PM
meirion1's Avatar
"Is this worth the effort?"
Have alook on ebay and see what they fetch with new bushes?
Old Apr 7, 2016 | 12:03 AM
dsetter's Avatar
Is the bush the same as the lower shock bush or something different?
Old Apr 7, 2016 | 12:48 PM
Priced up a bush set at £42+ delivered from ebay-If you factor in the cost of a garage pressing them in (assuming they have the correct mandrells) then unless you have a press yourself this is not viable- Still worth the question.
Old Apr 7, 2016 | 10:20 PM
dsetter's Avatar
Do these seem to be it?
C2C18350, C2C36866 or is it C2D4013 or are these all the same?
These are available from $30/pair.
I think mine have a rattle, after 170k miles. Have changed the front bushed and all other bushes, except this one.
Old Apr 7, 2016 | 10:21 PM
dsetter's Avatar
Can you share a link of what you were seeing?
JimC64
31
Apr 23, 2016 05:32 PM
odisyus
Apr 11, 2016 07:03 AM
Ophitoxaemia
Mar 19, 2016 05:04 PM
XKR2000
Mar 13, 2016 06:52 PM
1997Sovereign
Feb 29, 2016 09:28 PM
