Front upper shock bushings
Old Dec 14, 2014 | 01:35 PM
Dooley86's Avatar
Default Front upper shock bushings
I inherited my father's 2003 xj8 and the front upper shock bushings are deteriorating. Would I be causing damage to the suspension of I drive it in this condition?
Old Dec 14, 2014 | 03:41 PM
Fraser Mitchell's Avatar
Is your car the previous all-steel XJ8, (X308) or the new aluminium XJ8 (X350) ? The earlier car has separate shocks with upper bushes, the later car hasn't. So if your car is the X308, (as I suspect), then it would be best to replace these bushes as soon as you can, but the rest of the suspension won't be damaged. Only thing that might be is the body locating area if you let the bushes get so bad you get metal-metal contact.
Best to put more questions in the X308 forum if you have the all-steel car.
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
KarimPA
Sep 12, 2015 08:15 AM
1964Daimler
Sep 9, 2015 11:28 AM
Tar
Sep 6, 2015 11:24 AM
