Fuel Filter Replacement / head rests adj. ?
Old Sep 13, 2009 | 11:57 AM
Clifsmith's Avatar
Default Fuel Filter Replacement / head rests adj. ?
Anyone know where the fuel filter is located. Does the battery need to be disconnected to change it? I bought a new filter to replace since mine is overdue, but can't seem to locate. I have a repair manual on the way, but I wan't to go ahead and swap it out.
Also, how do you move the front seat headrests up and down?
Thanks.
Old Sep 13, 2009 | 12:50 PM
budsang1's Avatar
Not sure where the fuel filter is, but my headrests are power. The same switch that reclines the seat, it also moves up and down, which controls the head rest
Old Sep 14, 2009 | 08:36 PM
Clifsmith's Avatar
Anyone, know where the fuel filter is located? What panels if any have to be removed to get to it. It is driving me nuts. This is the last thing I have to do to it.
Old Sep 14, 2009 | 10:56 PM
budsang1's Avatar
http://wiki.answers.com/Q/Where_is_t..._on_the_XJ8_V8
Not sure if it's right, but found that on a quick search
Old Sep 15, 2009 | 07:10 AM
Clifsmith's Avatar
I looked there and did not see it. That might be for pre 2004 models. Surely someone on this forum knows. Please help.
Old Sep 15, 2009 | 09:04 AM
oldmots's Avatar
The fuel filter is under the left side of the body underpanel near the rocker panel, it must be removed for access.
Old Sep 16, 2009 | 07:27 AM
Clifsmith's Avatar
Found it, replaced it. Easy job. Like you said right under the left side of the drivers seat. You really don't even have to get under the car to change it out as it is right there on the side facing outward easily accessable by just laying on your side. Took 20 minutes to change. Just carefull as you will get about a cup of fuel coming out when you loosen the nuts. also, loosen at least 3 of those hose holder bolts so that you can get the hoses loose enough to pull the filter.
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
cheaperts
Aug 30, 2015 06:48 PM
dpappyp
Aug 27, 2015 06:31 AM
