Gear box default 2004 xj8
Get codes.
meamwhile fist check batterie condition and age. 12,4 volt it should have .recharge try again. If not 12,4 or older than 5y exchange
ground studs behind the headlghts clean brushed dialecrtic grease on them bolt just snug. Briddle
oil level in the transmission must be dripping out when engine running oil temp min 40degrees centigrade.
if the batterie is good you can do a hard reset by undoing both cables for 10 min and then hook them against each other for another 10 min .
after that you need window reprogram handbrake reprogram and radio code
Get codes.
Teemarie
May 27, 2023 06:53 AM
