Gear box default 2004 xj8
Old May 26, 2023 | 06:49 PM
Teemarie's Avatar
Default Gear box default 2004 xj8
Has anyone had a gear box default code and had to restart their jaguar? Mine is an xj8 2004, 100k miles, and this has been an ongoing problem.
Old May 26, 2023 | 08:00 PM
meirion1's Avatar
What code do you have?
Old May 27, 2023 | 07:20 AM
Petz's Avatar
Get codes.
meamwhile fist check batterie condition and age. 12,4 volt it should have .recharge try again. If not 12,4 or older than 5y exchange
ground studs behind the headlghts clean brushed dialecrtic grease on them bolt just snug. Briddle
oil level in the transmission must be dripping out when engine running oil temp min 40degrees centigrade.
if the batterie is good you can do a hard reset by undoing both cables for 10 min and then hook them against each other for another 10 min .
after that you need window reprogram handbrake reprogram and radio code
Old May 27, 2023 | 08:12 AM
Jaggiegal's Avatar
Default Thank you very much! Will give it a try!
Originally Posted by Petz
Get codes.
tyvm! Will give it a try!
Old May 28, 2023 | 10:58 AM
Petz's Avatar
Did you get any further?
Teemarie
May 27, 2023 06:53 AM
goldgun
22
Aug 28, 2022 10:22 AM
romroc
Jan 14, 2021 07:14 AM
Tundejag1
Nov 7, 2017 07:21 AM
