Gearbox/transmission conversion
Old Nov 15, 2013 | 01:45 PM
Tangomike7073's Avatar
Default Gearbox/transmission conversion
Hi,
Can anyone tell me if the five speed transmission from a 3.6L XJS will fit on a 4.2L XJ6?
Many thanks,
TM
Old Nov 15, 2013 | 04:36 PM
Fraser Mitchell's Avatar
What 4.2 litre XJ6 ? The old XK straight six engine, (last car left the factory in May 1987), or the 4.2 V8 of the much later XJ aluminium XJ saloon ?
Old Nov 16, 2013 | 04:00 AM
Default Straight Six
Straight six XK engine on a 1975/76 XJ6C.
Thanks,
TM
Old Nov 16, 2013 | 03:50 PM
OK, so you want to fit a late 5-speed manual gearbox, never originally fitted to the XK engine. I suspect this can be done, and there may be firms out there that do it, (for a fee). Either way, I suspect you will need a new bell housing, plus quite a few other bits, and probably a shortened or maybe lengthened propshaft, depending on the length of the gearbox. There will also be the problem of arranging the shift lever inside the car.
There is nothing insuperable in this job, just it may be expensive in relation to the benefit gained.
scooternva
29
Mar 25, 2025 12:45 PM
jagtoes
Apr 22, 2016 07:37 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Nasayr
Sep 9, 2015 06:20 AM
