Head Gasket job
Ok, got the right hand head off. Tip: use a rubber mallet to get your 1/2 inch socket on the head bolts good and tight before getting the breaker bar on it, i found that it would slip and start rounding the bolt heads. Couldn't see any gasket damage, will see what the other side looks like tomorrow. Pics attached of the cylinders & valves.
#28
#30
Received 2,580 Likes
#31
#32
#33
There's one other thing that you should be aware of. Now that you will have two of the heads off with the valves ground as well, that engine may begin to use oil afterwards (due to the compression now approaching the original specs).
So, at this point, you may want to consider overhauling/rebuilding the entire engine.
A case in point was when my father took both heads off a 1965 Pontiac Catalina back in the mid 1970s, and ground the valves. Afterwards, that 383 engine sure had plenty of newly restore pep, but it didn't take too long at all before the engine began to use oil. In fact, even before my father re-installed the heads, he told me that the engine will begin to use oil in the future.
#34
How can having the heads off and lapping in the valves cause an engine to use more oil?
#35
#37
#38
There is no mention of worn rings or excessive oil consumption anywhere.
So no reason to suspect that having the heads off and lapping in the valves would create such a situation.
I'm sure the OP would have mentioned it was blowing blue smoke or using loads of oil, but seeing as they haven't.......................
#39
With a better seal on valves, you will be able to create more compression as well as more vacuum. That said, any wear on the rings, widens their gap, increasing the potential for blow by. There by creating the potential for oil to enter the combustion chamber, increasing, or creating your oil consumption, as well as smoke from your exhaust, if enough is burned. My opinion, yours may be different
#40
