Headlight Flicker 2005XJ8
Old Jun 27, 2014 | 03:02 PM
ronrowand's Avatar
Default Headlight Flicker 2005XJ8
Occasionally headlights flicker on/off (with either manual on or auto switch.)
Old Jun 27, 2014 | 03:12 PM
Fraser Mitchell's Avatar
I had this, and it finally culminated in all headlights going off for about 2 seconds on a very dark road on a moonless night two years ago . The road was very twisty too ! Those two seconds can seem like eternity when your doing 40 mph !!
After that little incident I finally bit the bullet and sorted the job out. I had previously been troubled by the lights coming on in daylight on auto setting in bright sunlight and the satnav screen darkening. Study of the wiring diagram showed that there are only two moving parts between your finger and the headlights, (1) the lighting switch on the steering wheel binnacle, and (2) the headlamp relay.
In the end, a new lighting switch cured the problem. Study of the old switch showed somebody had tried to fiddle with it, and I believe these switches have been a regular cause of trouble. They cost about £125
Old Jun 27, 2014 | 04:20 PM
34by151's Avatar
Check its not the park lamps
If you have LED lamps installed the park lamps occasionally flicker or pulse on/off after you shutdown the car
As best i could tell the reason is the lower resistance of the led lamps is messing with the FEM. Even the canbus lamps do this
I did some testing and added a 150ohlm resistor inline which seemed to cure the problem but never got around to installing them permanently
When it happens I just use the remote to turon on the off for the headlamps
34by151
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
goges
Oct 5, 2015 04:53 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
