Headlight goes off
Old Feb 14, 2013 | 01:21 PM
merlinpjl's Avatar
Default Headlight goes off
My nearside headlight intermittently goes off whilst driving.
The fault has the symptoms of a loose wire or dry joint but tapping around the area of the headlight doesn't make it go off.
The light doesn't seem to go off if I hit a bump in the road or anything.
The headlights are HID type, is this a sign of the bulb going? I don't know enough about HID bulbs.
All ideas welcome.
Old Feb 14, 2013 | 01:29 PM
carzaddict's Avatar
when it goes off....does it come back on or stay off completely? turns back on another day?
when they are on, are both bulbs the same color? sometimes a bulb thats going will be a different color, or not as bright
it could be a problem in the connection.
Old Feb 14, 2013 | 03:52 PM
psg's Avatar
psg
Thats typical of an HID bulb at the end of its life, turning off and then coming back on after a few seconds to a minute or so, that along with flickering.
Stu
Old Feb 15, 2013 | 01:44 AM
merlinpjl's Avatar
Ah, right, it does come back on intermittently too.
I'll check the colour of the lights this evening.
Is this a dealer part, or can I get them somewhere else?
What sort of price should they be?
Old Feb 15, 2013 | 05:06 AM
Fraser Mitchell's Avatar
Bulbs are a common auto part, not specific to Jaguar, and loads on the internet. Fitting can be a PITA, though. They are not cheap on the internet either ! Here's a UK site
Bulbs: JAGUAR JAGUAR XJ8 SALOON HID XENON 2003 (03)
Old Feb 15, 2013 | 02:54 PM
N9921x's Avatar
Smile Search amazon D1S
When you find the ones you want, get two of them so they match in brightness, color, etc. I got 6000k and love them. Reasonable price compared to osram oems.
Old Feb 16, 2013 | 09:48 PM
H20boy's Avatar
Only way to know for sure if its a bulb or the ballast is to swap bulbs with the other side. If it moves...its the bulb. Stay put, its the ballast. Here's a thread to help get both out of your car by yourself.
https://www.jaguarforums.com/forum/x...-lad5gl-89738/
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
