Hello All
Old Aug 13, 2022 | 07:54 PM
Snoopy69's Avatar
Default Hello All
Hello All,
I am the proud owner of a 2007 Jaguar XJR with 80,000 miles on it. I've had a 1994 XJ12 but the 2007 XJR is a whole different beast. So after owning it for 2 days, I hammered the throttle at about 5MPH and the following things occurred:
1) Car accelerated for about 1/2 a second, car lurched, check engine light came on and the engine died.
The car was in D at the time with the traction control on and NOT in SPORT mode.
I coasted into my driveway, put it in park, and turned the engine off. After approx. 2 minutes, turned the car back on, and there was no check engine light and the car ran fine.
Im still new to this car, so dod I do something wrong? Any insight would be greatly appreciated.
Best Regards,
Eric Schutte
Old Aug 15, 2022 | 12:19 AM
Etypephil's Avatar
Default Codes.
Welcome to the best kept super saloon secret.😎
You did nothing wrong; with normal maintenance and care, these cars can be thrashed for hundreds of thousands of miles without serious trouble.
As your EML illuminated there should be one or more stored codes which will help locate the problem. Read the code(s) via the OBD port and post your findings here. It’s probably nothing too onerous to deal with; a dirty MAF sensor or choked catalytic converters. The latter not too likely at such a low mileage.
Old Aug 15, 2022 | 05:52 AM
Wingrider's Avatar
Vacuum leak is another possibility, good luck on your quest.
Old Aug 15, 2022 | 08:07 AM
clubairth1's Avatar
Community Influencer
Hope you like your XJR but can you do the repairs?
If not it will be expensive car to own.
As posted above you will need something to read codes. The factory setup is SDD which is a big project. There are aftermarket scanners that can do a good bit too. So yes please get the codes read and then erase them all. Then drive again like when you had the problem above. We want to only see fresh codes from your current problem.
Hard to say but you might consider a plug replacement and you also might have some COP (coil) problems. But let's check the codes first before buying any parts.
You did not ask but I would for sure put a transmission fluid change on your list of maintenance projects.
Simple stuff too like have you changed the fuel filter? Most people don't and I have found cars with 100K+ miles on them with the original fuel filter!
Old Aug 15, 2022 | 10:26 AM
scooterforever's Avatar
As others have said, pull the engine codes (check for pending codes too) and post those here. Check to see if any 'freeze frame' data shows up on the OBDII scanner as well.
Old Aug 16, 2022 | 05:35 AM
Robert Edwin rawle tangerinedream1's Avatar
Originally Posted by Snoopy69
Hello All,
Best Regards,
Eric Schutte
Engine lights on before you do any thing let your petrol go low put a fuel cleaner in like redex full big bottle of injection cleaner take for a good run put the gearbox in manually and hold the revs in each gear for about 30 seconds at full revs this should help clear out any bits in the system that's what I do to my 2005xjr I know these engines inside out I used to build them in the ford engine plant Bridgend South Wales UK Britain and machine the engine block and when the x350 came out I was in Swansea axle plant south wales UK Britain on the launch of the car I used to make the axle diff in 2001 if this will help the ratio of each axle to engine is 2.7.cc diesel is 3.07da petrol 3.0cc 3.31fa petrol 4.2cc 2.87da supercharged and normal asperated na from Robert Edwin rawle South Wales UK Britain
2.7cc diesel is 3.07ea not da
JDog
Mar 6, 2022 10:23 AM
SpartanBadger
Nov 16, 2021 08:37 AM
JohnXJR6
Feb 13, 2021 11:09 AM
Viapa
Jan 9, 2011 09:49 PM
Don.Key
Jun 9, 2007 12:27 PM
