Help, which ballast # for the headlight?
Old Mar 21, 2015 | 11:25 AM
VinnyT's Avatar
Default Help, which ballast # for the headlight?
Passenger side is not working. Bought new bulb, nothing. Tried the drivers side bulb, nothing. Fuses good. So, it has to be the ballast. Question is which one?
LAD5G or
LAD5GL?
Thanks all!
Old Mar 21, 2015 | 07:55 PM
Luke2004xjr's Avatar
The LAD5G is what is on my 2004 XJR. Hope this helps
Old Mar 22, 2015 | 10:18 AM
tailfin joe's Avatar
Make sure you have good grounds I had this happen on my Acura I replaced bulbs and ballest then I found out I had a bad ground .
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
