Help diagnose an engine miss
Old Sep 15, 2014 | 11:48 PM
Gazoo2's Avatar
Default Help diagnose an engine miss
On a cold start, my 05 will high idle normally at about 1300 rpm for about 5 seconds. It will then slow a little bit to about 1100 rpm and develop a shake as if it is not firing on one cylinder. Within a few seconds more the idle smooths out to about 800 rpm and runs smoothly. A little longer and it settles into curb idle of 600 rpm. I have noted a strong acetone-like odor to the exhaust when this shaking issue occurs.
My OBD reader has logged no faults or messages.
Does anyone have any suggestions?
Old Sep 16, 2014 | 07:40 AM
oldmots's Avatar
This may be a reflash issue. There is a Dealer procedure to correct rough idle during start up. I had it done some years ago. If there were a mechanical problem, it would not smooth out so it must be software.
Old Sep 16, 2014 | 12:00 PM
XJ8JR's Avatar
I've had an 04 X350 and my current 05 X350 and both did this same thing. Its pretty common and not really anything to worry about.
Old Sep 16, 2014 | 09:11 PM
Gazoo2's Avatar
Thanks for your thoughts gentlemen. I'll inquire with my indie mechanic next time I see him.
99xk8guy
Sep 29, 2025 10:51 PM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 12, 2015 08:15 AM
Bowman
Sep 3, 2015 03:17 PM
laserguy
Sep 3, 2015 02:02 PM
