help window rolls down by itself
Old Sep 26, 2013 | 05:04 AM
mark campbell's Avatar
Default help window rolls down by itself
i have an 04 ---when i operate the rear passenger window from the drivers master switch it rolls down -even with switck held up --i even put in a spare switch with the same result----------window works as normal from its switch---any suggestions ???????-------thanks
Old Oct 1, 2013 | 04:57 AM
still can not figure this out ----have spare parts --replace drivers master switch /door control modual /even switched passenger front and rear switches --------still window rolls down only when using drivers door switch -----------can anybody help --thank you in advance
Old Oct 15, 2013 | 12:41 PM
oldmots's Avatar
I have the same problem with my front passneger window. Now that is aggravating!
Old Oct 15, 2013 | 01:10 PM
oldmots's Avatar
In looking at the wiring diagram, the window switches for each window on the drivers door pack and the individual doors are tied together, which means that the wiring for the up switch position on the drivers door switch may be broken or have a bad connection between the drivers door and where it ties to the individual door switch.. Now a matter of tracking it down, yea!
Old Oct 15, 2013 | 03:35 PM
oldmots's Avatar
I decided the switch is probably bad, so I ordered a new used one.
Old Oct 21, 2013 | 04:25 PM
oldmots's Avatar
Well, I was wrong! I replaced the switch, the window still goes down only with the drivers switch, no matter which way you move the switch! Tracking wiring is the next trick. Could be a broken wire where the door wiring bends.
Old Oct 22, 2013 | 06:53 AM
talked to a private garage here in atlanta --they only work on jags and rovers --------said the computers --plural need to be reflashed --since is a hail damage car with salvage title im waiting --3 weeks now for the state to come look at it ---then i will take to them
NS2000XKR
Jan 1, 2017 10:41 AM
hkmcmast
Nov 29, 2015 06:56 AM
JagBrian
Oct 1, 2015 12:52 AM
blackenedindustries
Sep 30, 2015 10:17 AM
